kirkfranks
OK I have searched as best as possible and I have not seen this anywhere.
I bought a couple Round Top European Screw Cap pens that are on sale at A.S. These are the satin finish if that makes a difference.
The Bushing is 8B which I bought also.
The Bushings / hardware measure as follows.
Large Bushing .5170 / Center Band .5185 OK
2 x .4410 (Nib end?)Bushings / Threaded Coupler(reducer).4385??
1 x .4270 (Clip end?)Bushing / Clip .4360 cap insert .4335??
I have question about the Clip end first. This seems much too small for the clip and will leave the clip protruding enough to be noticeable.
On the coupler bushings the bushing is over the size of the hardware and even if it was a perfect match these couplers have 2 beads similar to the beaded center hardware on the Cigar. It seems that this would maybe be better if turned slightly smaller than the hardware similar to the cigar Pen.
Does anyone else have experience with this pen?
Is my bushing set bad? Is the hardware (especially the clip oversize)
By chance was there supposed to be two of the smallest size and those work for the coupler ends?
Also of note is that this was a 5 pc bushing set.
There was a small sizing bushing for the center band tenon (I am guessing) but the instructions for the pen kit only show a 4 pc bushing set.
I will wait till I hear some opinions before I turn this kit.
Thanks in advance.
Thanks in advance.
