mrmartyking
When assembling my slims and comforts, the 7mm tubes are too tight on the transmission. What should I do? Silicone on the transmission, or what?
I have this happen on all of my bullet pens as I solder my tubes in and the heat shrinks it ever so little and making the tranny too tight, so I always file mine.When assembling my slims and comforts, the 7mm tubes are too tight on the transmission. What should I do? Silicone on the transmission, or what?
Lin.
Check to make sure you don't have any glue inside the tube.The upper tube is too tight slipping it over the silver part.
This works well and it's easy to do...I use my dremel rotary tool with a sanding disc.If you don't have any glue in the upper tube, Slowly file the dimples on the silver part of the tranny until it fits better, I have a reamer I use after I square my blanks
