6mm drill substitution
wdcav1952
Activities Manager Emeritus
I need to find a dril bit to substitute for a 6mm bit until I order a 6mm. If I understand the Hut conversion chart, 15/64 is the closest drill available. Is this correct, or what would be a decent substitute? I want to drill a hole to mount a bottle stopper blank on the Berea bottle stopper mandrel.
TIA,
Fred in NC
LANDIS, NC, USA.
William, from the home page you can access the references page, and the "decimal equivalents" which is actually a drill bit chart:
http://www.penturners.org/content/HUTDrills.pdf
The 15/64 is the closest bit to 6 mm:
6 mm = .2362
15/64" = .2344
Difference: .0018 or less than two thousands
For that small difference running the drill through a couple of times will probably do the trick. Most of the time a bit will drill a hole slightly oversize due to runout.
mrcook4570
Mason, WV, USA.
If you are using a softer wood, you may want to use a bit that is smaller than 6mm, as the hole will tend to enlarge while turning.
alamocdc
San Antonio, Texas, USA.
Bill, the link I placed on this thread has a very large variety of sizes and the prices are pretty good... $3 and change for a cobalt bit and $1 and change for Vermont Tap and Die brand. http://www.penturners.org/forum/topic.asp?TOPIC_ID=7929
DCBluesman
Passed Away Mar 3, 2016
WOODBRIDGE, VIRGINIA
Originally posted by wdcav1952
<br />I need to find a dril bit to substitute for a 6mm bit until I order a 6mm. If I understand the Hut conversion chart, 15/64 is the closest drill available. Is this correct, or what would be a decent substitute? I want to drill a hole to mount a bottle stopper blank on the Berea bottle stopper mandrel.
TIA,
Per www.arizonasilhouette.com
Drill a 6mm hole into the stopper blank, screw in the threaded end of the mandrel into the blank, insert the smooth (round) end of the mandrel into a 3 jawed chuck, Jacobs drill chuck, et. and turn away. The threads of the mandrel match the threads on both the all-chrome and cork & chrome stoppers. A 15/64" drill bit is available for a smaller hole when using softer woods.
wdcav1952
Lou, surely you don't expect me to read directions all the way to the end, do you? [:D] I got a 15/64 drill at Lowe's this afternoon, and it listed 6mm as the metric equivalent. So, I guess I am set. Thanks to all for your input.
