Same question....
I have some Devcon 5 minute epoxy that is quite new, but the last time I used it, it seemed to get thick way before the 5 minutes. I am careful to follow the 1 to 1 ratio and mix well. Some of the tubes did not bond as well as normal.
These were going in acrylic blanks that I had painted inside the tubes with spray white primer. They were left to dry for several days, and the epoxy was mixed and used in my kitchen, so everything was around 67 degrees. The epoxy doesn't have a date stamped on it, but as I said, it can't be more than 3 months old and is kept in my office, again around 67 degrees.
I don't mean to hijack this thread, but since I have the same experience as Ed, I would like to ask if anyone has experience with longer-work time epoxy? According to a friend, it has a much stronger bonding than the 5 minute stuff. I looked at some 11 or 12 hour stuff, but it said it was only to be used above 75 degrees, and it was decidedly amber colored.
