does anybody know if a 3/8 tube from smitty and a 3/8 tube from psi have the same id I got some tbc bushings and they wont fit the smitty tubes I don't have a psi to try them in thanks
The nominal size used is commonly that of the drill used to make the hole ie the 7mm tube fits into a hole drilled with a 7mm bit and has an internal size of 0.248 inches.
Get the calipers out and measure the TBC bushings carefully and compare to the tube tables for the pens of interest -- We have awesome information on the tubes and bushings in the Library (many grateful thanks to Wayne)!!!!
