mranum
So I finished my second attempt at a slimline pen yesterday. But I have a question about my CA finish for you experts. When I had the blanks done and sanded through 600 grit I put on some Watco Teak finish I had then buffed dry with a rag then put on a heavy coat at slow speed of Gorilla super glue and proceeded the get the surface all cloudy and rough. So I lightly sanded that down with 600 again then put on a lighter coat at roughly 1000rpm. I did not keep pressure on it till dry I just put it on smooth then just let the lathe run till it was dry. The finish has somewhat of a grainy or pebbly texture . Its not unpleasant and actually looks fairly decent with a fair amount of grip to it. In retrospect, I didn't use paper towel and instead used a cotton cloth to apply the finish with, probably not a smart move.
Question is what should I do differently to get more of a glass smooth high gloss finish? I debated about buffing but decided against it for this time anyway.
Critiques are welcome.
