Codesman
I've not made pens in quite some time and starting to get back into it. Started to make my first 223 pen today. Have made several 100 cartridge pens but never 223. Using slimline kit. Drilled bullet and loaded into casing and secured tube with no problem. The problem I am having is that the 7mm tube extends out of the casing with the transmission. I made the upper part and made the wood longer than the tube so it extends over the tube in the casing. Since the upper tube wood is so thin it broke. I have not found any tutorials on this and am stuck. Any suggestions (photos) would be appreciated.
