tbroye
I am making 8 Sierra/BOW Pens for members of our Church Council. I turned the 8 blanks on a mandrel 2 at a time. When it came time to assemble them I found one end on 4 of the blanks were out of round. Started checking and found a difference in the ID of the tubes and how they fit the bushing. Some were tight and others were loose. Ordered 2 sets of new bushing from AS and found the same problem. So I made up a new blank and rounded it off using the Mandrel and then finished it using the Live/dead center method with the bushings. Came out perfect and extremly smooth no sanding required. Applied a 6 coats of thin CA sanding with 600 wet dry paper bdtween coats and finished with MM it to 6000 and perfect, not too dull not too glossy. Assembled the pen and nice fit. i think the blank I had problems with were the ones closest to the tail stock and on that end of the blank. Between the bushing, ID of the Tube and the mandrel is what caused the problem. Next get a good caliper and try turning with just the centers. Now to turn 3 more blanks and I will be done, might try to sand the out of round blanks to see I can get a better fit on the out of round end
