12mm barrel trimmer
bking0217
Apopka, FL
I got in on Smitty's Jr. Gent 1 pre sale. The kit calls for a 12mm drill bit but I don't have a barrel trimmer that big a can't find one anywhere. I want to have everything before the kits arrive so if someone could tell me where to get one, I would appreciate it.
JBCustomPens
Everett, Washington
Here's an easy tip, (don't worry, it takes only like 1 hour).
Take a cheap piece of wood, drill it with a 7mm drill bit.
Glue in a slimline tube.
Turn the piece down till it tightly slips inside the 12mm tube.
You are done. Easy.
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
Drill
Well don't get to hung up on the 12mm drill bit....CSUSA's instructions call for a 15/32 drill bit instead of 12mm and 25/64 instead of the 10.5mm and both work just fine with my kits.
Rick_G
Bothwell, Ontario, Canada.
I quit using a barrel trimmer a while ago. They dull quickly and are not easy to sharpen. I glue in the brass tube then using my bandsaw cut the blank close to the tube at both ends. Mount the blank between centers on the lathe and using a thin parting tool on it's side part the blank off even to and square with the brass tube. Works for all tube sizes and when the parting tool gets dull it's easy to sharpen.
louie68
USA
here's what i do with barrel trimmers i take the barrel part off stem get fine hone stone lay on flat table take the barrel shape blade lay flat on hone stone just like 180 degree and drag it equal times per side of each blade example say 3 drags per blade but do the side that cuts, it works for me, better than when it was new, still cutting blanks not dull yet. my .02 cents
ldb2000
Laurence Harbor, NJ, USA.
You are done. Easy.
Be real careful about how tightly it fits , too tight and you stand a chance of heating the blank by friction and weakening the glue that holds the tube to the blank . a "Close enough fit" is more then sufficient to keep the trimmer aligned to the tube .
JBCustomPens
Everett, Washington
You are done. Easy.
Good point. I guess I should of said until it fits with no slop.
