10 inch turn crafter commander value - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 11-08-2018, 01:55 PM   #1 (permalink)
Photos: 0
Default 10 inch turn crafter commander value
I have located a turn crafter commander 10 inch lathe that is really nice. What is the lead like this worth? The seller isAsking $200 for it
Chitreano is offline   Reply With Quote Top
Old 11-08-2018, 02:42 PM   #2 (permalink)
monophoto's Avatar
Photos: 0
Default
There are two versions of the 10" Turncrafter Commander lathe. One has an array of pulleys, and allows selection of five fixed speeds from 650 to 3000 r/min. It's listed (new) for around $350, but can be found on sale for as low as $250. The other has two pulleys, and electronic variable speed that allows the speed to be adjusted infinitely over both a high and low speed range (the exact ranges can be tweaked using potentiometers on the speed control circuit board), and the price (new) is listed at around $430.
These lathes are made in China, so the pricing of new units is subject to tariff considerations.
$200 might be a reasonable price for a used variable speed model in good condition, but it would be excessive for a used multi-speed model.
Either is basically a good lathe when new, so the issue is what is the condition of the used lathe. In addition to obvious issues, check the condition of the belts (Penn State does sell replacements), and also listen carefully for signs of bearing problems. Both have plastic indexing wheels, and it's easy for teeth to become broken if the indexing feature is misused as a spindle lock. Obviously, bearings and indexing wheels can be replaced. With the variable speed unit, check that the speed varies in uniformly as the control knob is rotated.
__________________
Louie
http://monophoto.deviantart.com
Instagram: @louie_powell_photo
monophoto is offline   Reply With Quote Top
Old 11-08-2018, 02:43 PM   #3 (permalink)
Dalecamino's Avatar
Photos: 222
Default
Depending on which model, PSI has them for,
Variable speed = $399.95
Multi Speed = $249.95
I have the 7" swing variable speed, and like it.
__________________
Chuck Hutchings
Indianapolis, In.
You can see some pens at http:www.facebook.com/chuckspens
Dalecamino is offline   Reply With Quote Top
Advertisement
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
