FIXED 1/8" Short Sierra
OK, because of your comments, the pen is fixed!
1. I did make a mistake with the bushings. I used the 20A instead of the correct one.... Solution next time.... mark on the bag the bushing to use!
2. Yes, because of the incorrect bushing, eagle eyes will spot that this pen barrel isn't EXACTLY the diameter matching the hardware (lesson learned)
3. I had enough poly left that I did not turn down to the material... I call myself lucky on that one
4. I used two pieces of an old leather belt to disassamble the pen. One piece slid under the clip on the barrel and was tightened in the vice, the other leather piece wraped around the final end and I used pliers to twist it loose.
5. The transmission appeared to be very slightly at an angle (similiar to when you try to screw on a nut and it doesn't catch "just right"). I was very careful to "straighten out" that flaw when pressing in the transmission 1/8" further into the final.
6. To accomplish #5 above... I first lined the pen parts up to check how much I actually needed to seat the barrel. Then I used a black marker on the transmission where it entered the final. Finally, I used my pen press to nudge the transmission to the black mark.
7. Assembled the pen. At first the pen end showed but would not withdraw. With nothing to lose, I simply started twisting it back and forth and then it worked. I presume that a small part of the actual mechanism was in the final and my twisting rubbed smooth just enough of the mechanism housing to allow it to work.
That's it.... my thanks for all your input. I learned a few things and hopefully will eliminate some potential future errors
-joe L
