This took me quite a bit of time to complete. I am not so sure I went about it the wrong way. Listening to some other opinions, I still feel that had I gone another route I was destined to failure? IJDNK? Anyhow this did work, alibiet, alot of work! My biggest concern was the "oh so small" holding of the inset tubes with the Inlace inside of the tubes! Going about as I did I feel the CA had a better chance of holding as it was glued inside and out. I did cut the tubes and belt sanded the cornerS off the blank before turning. Super sharp Carbide bits and really light cuts did the trick! This is Spalted Sycamore w/Inlace & Brass inserts. C~N~C welcomed. Thanks and be well.............Jan
...original post is here .... http://www.penturners.org/forum/f13/work-progress-109170/
