William's Finish
See more from StatProf
StatProf
Richardson, TX, USA.
Dear All,
I had a couple of pieces glued up and decided to try William's finishing technique that has generated a lot of talk in the last couple days.
http://www.penturners.org/forum/showthread.php?t=43539
I must say, this is the best finish I have ever done! Even though I am not a good photographer, you can still tell just how good the finish came out. I did one thing different, though. After I put on 6 coats like William suggested, I wet sanded to 12000 MM and didn't use plastic polish. It is hard to tell on pictures of the elk antler, but this is the first time that I was really able to get antler that shiny. Those of you who work with elk know just how hard it is to get this stuff to have other than a matte finish. The other pen is BOW.
One caution, though . . . I am used to cutting and sanding past the bushings and then building back up. As the pictures show, if you use this method, this is a huge mistake. I am just shy of the rim of the pen on both pens. Lesson learned. This method uses just a little CA, but I love the finish.
Thanks a ton William!!!
StatProf
W.Y.
BC, Canada
StatProf
You are quite welcome and glad you liked the process.
Your finish looks great apart from the fact that the blanks are below the bushings. I had never heard of sanding below the bushings like that and filling up with CA. You must have been using a LOT of CA . Was it not sticking to your bushings when doing that or were you putting them between smaller centers and using a micrometer to bring back to the correct diameter ? Even then a lot would have to go out over the edges.
Perhaps you were using a method I have not yet heard of.
