White Tail Antler & Wood Fountain Pen
See more from Texas Penworks
Silsbee, Texas
This pen was made from White Tail Deer Antler, Teak & Ebony woods accented with a 24 kt Gold Tycoon Fountain Pen Kit from PSI. It was a little tricky getting the antler ends square but it turned out ok in the end.
very nice...but...when challenged...go with the issue..just keep square...and cut on the table saw...glue the stack before you drill...and then drill...I found the flowing joints looked better than straight...sort of looked.
I orginally did this to offset a short blank...seems to work..and much easier than turning and glueing...justo offering....but I do keep all the ends to blanks...either drilled or not...and just piece them when have blowouts...ends up these look pretty good...
