What Is It?
See more from broitblat
broitblat
Bellevue, WA, USA.
This is a new material I've tried working with. Any guesses on what it is?
More information to follow.
-Barry
maxman400
Omaha Arkansas
It looks like what I have been looking at, at HD. epoxy chips that you spread on your garage floor after sealing it. If it is I was thinking a green resin and brown chips for camo.
bruce119
Franklin, NC, USA.
Perhaps robin egg shells you can see blue with white flecks on one side and white on the other at first I thought aluminum foil but with a closer look it's too thick for foil and the specks don't fit. I still say some type of blue egg shell I don't think it's paint chips because the color would be the same through the chip. It is clearly blue on the surface of a white material and the tube is painted black. Does look nice though.
Len Shreck
Pennsylvania
I will guess either acrylic Shavings from either a drill/cut or crayon shavings in acrylic. Just a guess from a total newbie. When you going to let us know?... Len
broitblat
Bellevue, WA, USA.
Well... that didn't take long.
It's labeled "Quikrete Color Flakes (Blue Mix)". It is the flakes/chips that you sprinkle on an epoxy garage floor coating. I'm not sure exactly what they're made of, but you buy them in a little jar that has different shades of chips. It's cast in clear resin. The tubes are painted white but I don't think that was needed.
Points to Kirk and Max.
-Barry
