Have you ever done a CA finish on it? It gets much darker. I have done a lot of pens with CA and Wenge. Let me know if you want some pics or not.
hey iam open to try CA finish but what am insupoosed to use? can you find something exactly on czech market?
thank you
Sent from my iPhone using
Penturners.org mobile app
The CA is the abbreviation used in the pen turning world for the super-glue, I'm sure you will have that product in your country. Look for one that is of thin viscosity, ideally, we use 2 viscosities, thin and medium but the thing is more important as it penetrates the wood better the only difference with thin and medium is that you will need to put a few extra coats with the thin, we normally use one to 2 coats of the thin and then 4 and up to 20 coats in some examples, I normally do 6 medium after the 2 thin.
There is also a product that is normally associated with the CA (super glue) and that is the Accelerator, this is a specialised liquid that is sprayed on the CA to make it dry faster.
There are other items necessary to do a CA finish but those you can always get later after you find the super glue and accelerator.
Cheers
George
