Two Navigators
See more from VampMN
VampMN
Rock Hill, SC
Finally getting around to posting some pictures. I mostly lurk, but I thought I'd show some of my pens, since pretty much everything I know, I have learned reading on this site.
First one is the first navigator I did. It's chrome with Bloody Jasper Tru-Stone.
Second is the other Navigator I've done. It's also my first attempt at doing any kind of customization to a kit. It's Gold with a Black Cherry acrylic blank from Woodcraft. I turned the finial and the and the centerband to match. The finial came out a little smaller than I wanted, but over all I'm pretty happy with it.
Sorry the pictures aren't great. Still working on that. I would appreciate all comments and feedback. Good or bad. Thanks!
VampMN
Rock Hill, SC
Thanks for all the comments! These are the two pens I'm most proud of so far.
Jennifer, for the centerband, I mounted the cutoff as directed in this pdf; http://content.penturners.org/articles/2008/custom_finial.pdf
I then took the kit cb and measured all the dimensions I could think of with a set of calipers. I turned the blank down to close to final diameter, and drilled a hole the same size as the hole in the kit ring. I then used my skew to start a parting off line, but stopped short of going all the way through. I then sanded and mm, etc, before parting the rest of the way off. I then parted it the rest of the way off, then sanded, etc. the flat sides (very carefully). I hope that makes sense. Let me know if it didn't.
bitshird
Adamsville, TN, USA.
Very nice pens, Now tell me why you were concerned about entering the PITH, you did a very nice job on the modded Center band and Finial and I would be proud to own either of those pens, they are great.
VampMN
Rock Hill, SC
John, I sure wish I could take credit for that finial, but I found it here in the library. So much great information here.
Ken, thank you so much for your kind words. I guess I was worried, because these are definitely my best pens. My others aren't as good. But I think they are steadily getting better. Hopefully I'll do whoever I get as a partner in the PITH justice.
BTW, I've been using my bowl pro, and I love it. Still getting the hang of it, but I really like it. I turned a nice Jobillo handle for it. I was pretty happy with how it came out. Maybe I'll take a picture to post.
