Transparent Cap.
See more from Mongefelipe
Mongefelipe
Lakeland, Florida, USA.
Double Closed end Churchill Pen in Brown PR. And Transparent PR cap.
Radman
Omaha, Nebraska, USA.
Nice pen, but if there's a slight jarring, ink may run out of the nib and make a mess inside the cap. I like the concept, profile and craftsmanship.
[8D]
Scott
Blackfoot Idaho
Felipe!
This is an absolutely stunning pen! Thank you for making it! And thank you again for showing it!
Scott.
csb333
Nashville, TN, USA.
That's so sharp, and another pen that I would purchase if I saw it in a store. I've tried to drill something clear before but there was no way I could get it clean on the inside. Do you mind telling how you did it in more detail? If you would rather not tell, I will understand. It is a fine looking pen.- Chris
Mongefelipe
Chirs
I drilled the hole in the cap blank.I then got the hole clear by sanding 220-1000&polishing with ,Tripoli,White Diamond,Renaissance Wax.I wrap sand paper and
cotton boll for buffing in a dowel.
