Thanks Charlie.
The glue up was with thin CA because I was out of medium, which I think works better. Keeping the glue from showing is tricky, at least for me.
After turning and dry sanding to 600 grit, I wet sanded, cleaned with alcohol, 20 coats of thin CA, wet sanded, polished, then buffed it. That is becoming my usual process.
I'm still trying to figure out how to make the pictures thumbnails, but if it was enlarged you can barely see the difference between the black wood and black plastic.
I order different colors and thicknesses (1/8, 1/4 and 1/2") of sign plastic which works well for pen segments as long as the blank is back painted on thin pens.
Thanks again.
