Sterling & wood pen, pure silver holder
See more from jrc
jrc
Bristol, Vermont, USA.
Something new I'm going to try. The pen has sterling parts and the leaf is silver clay which is 99.9 pure silver. I used a leaf skelton to get an impression on the silver clay. Heat it with a propane torch for ten minutes and you have pure silver. The possibilities are endless.
jrc
The silver clay at the top, the leaf tip you can see the thickness. The first one is thinner but still very strong. You can work it and bend it if needed. You can fire some pmc clays on a gas stove. Check out PMC 3 silver clay on Google.
jrc
This is something new from Japan, mid 1990'S. Leave it to Japan to develop something wonderful like PMC Clay. The first PMC clay would swrink up to 25%, the newest PMC3 swrinks up to 12% and fires at a much lower temp. Like I said check them out on Google. I got a starter kit from http://www.pmcsupply.com/index.html
PMC srands for Precious Metal Clay. The clay dries overnight and hardens enough to hold to sand the edges and clean it up before firing.
jrc
That one is mounted. I will make them with the bottom open where the desk pen refill will stay extended. Later I will make pens to use parker or rollerball refills that will not retrack, so there allways ready to use.
jrc
I've thought about that but every different wood I use to make a pen I would have to make a stand out of that wood also. That's more than I can keep up with. I'm hoping next year I can sell several of these pens and stands and less of my other pens. I will not have much time to spend on the desk set till after Christmas. So far I have orders for 500 pens and my busiest time has not started yet. I'm passing on orders to my sister.
louisbry
Tullahoma, TN, USA.
Sorry, I didn't know that this is your intended mounting. I wrongly assumed it was in the rock for purposes of safely putting the torch to it. At any rate it is a great idea with beautiful execution.
jrc
I have some better photos. I let someone borrow my photo cube and lights and now I have them back. I realy get much better photos with it. Pen holder are made from the PMC Silver Clay
Bonsi Maple seed
