Steam punk Gears
See more from maxman400
maxman400
Omaha Arkansas
I found these small gears at a bead shop, the first one is on a black painted tube and the second one is on AC foil tape. They are cast in Alumilite and are on sierra vista pens.
Comments welcome, Thanks for looking. :biggrin:
WoodLM
Indianapolis
great pens! i really like the foil one! how do you get the gears to bend around the tube? are they thin enough to just bend by hand, or do you use something else?
MarkD
Sayre, PA
Looks great.
It would look even better if you could get all the gears to be engaged as if the gears were driving each other. It looks like you were close to that on a few of the gears.
maxman400
Omaha Arkansas
They are thin and are not tempered, I can bend the majority of the gear with my hand. The very edges I clamp with a wooden clamp on one side and tap the opposite side with a brass hammer, then repeat for the other side.
