alamocdc
I got this Willow from Dario. Some may remember his post about whether or not it would be turnable some time back. This is the last of my poly stabilized blanks. I start turning the plexi stabilized stuff tomorrow. I have to admit that this one turned out much better than any of the other poly stabilized species, but I'm not sure why. They all turned about the same. They were all VERY difficult to sand though... the poly gums up the sandpaper very quickly. Solved this by applying 3 coats (instead of 2) of Deft Sanding Sealer after the 220 grit. Then sanded with 320 and all the way out with MM. Finished with homemade lacquer based FP.
