Robert111
I spent quite a few hours on this one. In fact, I spent a few days on another attempt, which I won't post. I took some good advice from a fellow pen maker and then went to work on this one. Comments appreciated. Thanks for looking.
Weight 26 g
Overall length 135 mm (5 1/4")
Uncapped 125 mm (5")
Cap posted 170 mm (6 3/4")
Cap diameter 17.5 mm
Barrel diameter 16.5 mm
Section diameter 12mm
Polished steel #6 Meisternib (Jowo)
Below: This clip comes from a Polaris and is rhodium plated. $6.95 from PSI for the kit.
Below: The barrel to cap threads are BIG--16 x 1, but they're very smooth. BIG was necessary for the stout shape.
Below: It looks like an exposed clip ring or a band, but it's not. The material is transparent enough so that the clip ring shows through.
Below: The section is very thin at the waist.
Below: The blank is called Gray-Black Pearl and comes from Ed and Dawn at Exotic Blanks.
Weight 26 g
