Hi Marcia~I will explain to you how a "millefiori cane" is made. I have included photos on the bottom that I will refer to.
The first thing I do is get the components together to make the design, here I had to condition all the clay then make the hat, scarf, nose, etc. Then put together all the components; at this stage snowman was pretty big!!
then you need to pack it with clay, I use translucent for all my designs so they can be applied to other designs as the translucent becomes clear. Rudolph is packed with translucent clay.
After that its time to reduce the cane which involves squeezing
chooking
the cane and slowly it will begin to get longer
and longer in the 3rd photo you will see the snowman in various lenths and diameters.(he was a big boy)
the last photo is what the cane looks like that Gary is using to apply to the tubes to make his pen. You take slices off of the cane or canes to make the design. You can use as many different canes you would like, its all up to the artist...
I hope that helped explain what a cane is...:biggrin:
(Lenny no wise cracks:monkey
