Segmenting a cartridge case
I know there are several knot tutorials but could you do one on the cartridge segment pens. I love the one for red, wht, and blue.
I have a tutorial posted at
http://content.penturners.org/articles/2009/6-Segment-Knot-Pen.pdf
This is how I do all my segmenting. For a cartridge case there are a few added steps:
I use new brass because the inside has to be clean.
Fill the case with JB Weld up to the neck of the case.
After the JB has set, drill with 1/4" bit.
Because of the taper in the case, you have to build-up the outside.
I have cast them in PR, but that takes too long to set for me, I want to do it NOW not the next day. Now I make a paste of powdered oatmeal and epoxy. It takes two or three applications to get a good thickness before I turn it round.
If you turn between centers as I do, be careful not to apply too much pressure or you will flare the bullet end of the case.
After turning round, treat is as any other round blank.
Hope this helps.
Later
