Salsa acrylic , ebonite section
See more from Texasshipagent
Chesapeake, VA
Jowo italic nib
Sent from my iPhone using Tapatalk Pro
OZturner
Sydney. NSW. Australia
Spectacular Pen William,
Glorious Blank, Superb Profile, Proportion and Section.
Superb Finish.
Excellent Clip and Finial.
Have you done anything with the Center Mark on the Finial?
Co
Chesapeake, VA
Actually that's not a center mark it's just the darker color in the acrylic , demised me a bit till realized just part of the blank
Chesapeake, VA
Very nice indeed !!!!! . Which clip did you use ?
Not sure, I bought some from a guy in England, however the local woodcraft store owner is really nice and has a giant Tupperware bin of mix match parts from where people bring in broken kits for return or need a replacement part, and let me take the clips for free
Generally for kitless looking for a clip with an ID of ~10mm and OD of ~12mm, as can turn a tenon and thread the cap butt in, but still have room inside the tenon for the upper most part of the nib, I then I make a small inner cut for the clip ring to recess, and make a break for the clip stanchion with the drimmel tool
This size seems fairly essential to avoid a disproportionate cap size, as smaller ID clip rings made the tenon drill size to small for the nib point
Am looking to experiment with cutting the bands and soldering a bar to fit in a slot and bend down the wall of the interior
Then would press fit (or use a small screw) a derlin cap insert so can keep the cap all one piece and reduce drilling (and time)
Also have a roll stop experiment underway for clipless using dermal body jewelry heads which I found be bought with threaded posts in larger wire gauges then traditional earrings
