I like it! I noticed the date ring is separate. I have a few watch faces, not Rolex, that have the date ring and was debating on should I do it serarate like you did or try to put a date in the box where it normally goes. If I try putting it under the face it would be too bulky and give air ample room to hide and cause problems. The other solution would be to try to cut the number out and glue it in the window but I'm not sure I can make it fit the way I would want it to. Thanks for showing.
