Drstrangefart
Here we have it. I found a lot of bubbles in the epoxy mix, but I did what I do and padded up a lot of layers of medium CA and sanded it back down over and over until most of them were history. A couple of tiny ones left. It turned nicely, and the epoxy made some great ribbons. It cuts nicely. I'm pretty sure next time I'm planning ahead a bit more and using some old spalted water oak I have from some of the first blanks I ever harvested. I think that will make a better contrast and look a lot better. Also, more elaborate cutouts will be in order. I'm happy that I can add this to the bag of tricks and use it on more ambitious projects later. Namely if I get my hands on some higher end kits or a few lower-end fountain pen kits. Either way, this is a cool project you can do without having to have a casting rig. You just end up investing extra time in shoring up the liabilities of the materials used, which is a completely acceptable tradeoff based on my experience. If I ever get set up to cast and can do proper worthless blanks I probably wouldn't do more of these unless there was a specific need, though.
