Rebar pen
See more from hunter-27
hunter-27
Passed Away Aug 14, 2013
Chadron, Ne, USA.
Ok, first off I'll start by saying TY to Peter for the rebar idea. I decided to make it my own a little by adapting it to be a single barrel "slimline". Most of my tools are in storage awaiting the finish of my new shop(another thread) so I had limited tools on hand to work with. I had at my disposal the following:
Edit---yes I used a bit of oil, yes the nib twists, yes it is heavy but not as much as you think(about the same weight as a full size capped pen.
Drill press
Angle grinder
bar clamp
wire brush
hammer
pen kit
Here is the resulting product:
KenV
Juneau, Alaska.
I suspect you also used a fair amount of cutting oil to help the drill bit -- will have to look for some small pieces of epoxy coated rebar -- Looks like #4 (1/2 inch) rebar.
KiltedGunn
Local Chapter Leader
Baytown, TX
Very nice!
Guessing the nib twists?
And did drilling it out shed alot of weight or does this thing wiegh a ton? Just curious! :wink:
hunter-27
Chadron, Ne, USA.
better pics
Tried to get better pics on my limited skills.
CarpenterAnt
Asheboro, NC
Boy Landon, does that bring back memories, being an old rebar worker from way back.
I think Ken is right, it does look like #4.
Real nice job... Most expensive piece of rebar I ever saw!
markgum
Keenesburg, CO
now,,, your shop will be short 6 inches of re-bar and the whole project will be put on hold... :mad: you better get busy, if memory isn't failing to bad you have about a week before the snow starts flying in Chadron :eek:
interesting use of materials. great job.
