Ed, overall I think you did a fine job on it. However, I have two points for you, if you don't mind. 1) It appears that the upper blank (clip end) needs to be pressed together a bit further as you can see light between the blank and the CB. 2) The upper end of the lower blank appears rather abrupt where it meets the rounded pressed in threaded part. Ed (Ed4Copies) Brown recently shared his method for making this transition appear less abrupt and I've liked the results. Instead of leaving that end square, he rounds it over just a tad. Please don't take this as being critical. Just trying to give you some pointers.[^]
