Princess Pen
See more from MnkyNthMddl
MnkyNthMddl
Blaine Washington
Ok, here is a Princess Pen I did. It is made up of Blood wood and a laminate I made. They laminate is Blood wood, Bocote and Cypress. The finish is CA and HUT. I am not completely happy with the finish as I would like a little more shine. Also it is pictured on two different backgrounds because we are still looking for the best solution to photography. C&C always welcome.
SDB777
Cabot, Arkansas USA
White background is always your best friend, especially if it doesn't have anything to pull your eye away from the subject(ie, the pumpkin thing).
That segment is pretty tight, don't see anything wrong with it from my chair! Well done!!!!
Scott (finish is fine too) B
MnkyNthMddl
Blaine Washington
Thank you for your comments. I will look into setting up some proper lighting and using a white background. I think I have also seen clear stands so that I can see different angles of the pen when photographing.
Thanks again.
