Ruby pen turning
Last week I showed a Zen with a rainbow blank I had made. That blank was made from the extra resin that was used to make the polka dots in this pen. I turned the 3/4" solid color blanks to 3/8" polished them and sliced them into 3/4" section and glued them alternating colors into the 3/8" holes. I then drilled to the center of the blank on the sides and inserted the colored rods and glued then cut everything even with the sides of the blank found the center and turned round. It has some problems with gaps on the sides of the rods filling with sludge from sanding which I filled for the most part with a slurry of thick CA with black mica. There are several coats CA sanded and polished with Novus polish.
Thanks for looking.
Thanks for looking.
