Bree
A friend had some beams from an old 150 yr old Western NY barn. He wanted me to make him a pen from the wood so he gave me a big chunk of the white oak beam wood. Naturally it had some nails hidden in there and cost me a band saw blade (which needed replacement anyway). But I got some usable wood out of it... VERY DRY wood.
I turned it to what I thought he would like, Sanded to 240 grit put some sanding sealer on and continued to 600 grit. Then MM-12000 and a triple buff followed by application of a very small amount of my tung oil... just enough to moisten the wood with zero excess.. indeed barely enough to cover the wood. I heated that up with a friction rub and let it cool and dry. Then I put on 3 coats of CA/BLO and assembled it with a Black Titanium kit for a little contrast.
I gave him the pen last night and he was thrilled because he just knew that there was good wood in that beam! He talked about it and showed it off to his buddies and a good time was had by all.
:biggrin::biggrin::biggrin:
