Ruby pen turning
These are some of the steps to making this pen. Everything looked good and did go good accept for one brass rod that popped out two time. The second problem is that I cannot seem to get a hole to drill in the center of a blank to save my life. ( This is not the 1st pen I did not hit center) Third thing was the caps I glued on the ends had center holes in them already and those are what I used (not thinking) One was not centered and caused a wobble after cutting it off and gluing between centers. (barely noticeable on the finished pen. The blank was sanded through several grits sandpaper then fine steel wool. It has around 15 coats CA sanded then sanded again through all the pretty pads and finally polished with Novus.
Comments critiques welcome. Thanks for looking Brian K.
