J
But the PW can use a rope bit and the Legacy can use a non-rope bit.PW is on the left.Thats not done by a rope bit.
For those of you who have debated the merits of one vs. the other...can you tell which is which?
Can't you use the Legacy bit in a PW if you use a foredom instead of a dremel?You guys are sharper than tacks, that's for sure...I have yet to get the rope bit from JRB at Beall tools..so that will give everyone a clue...I have doubts about a 1/8 inch shank bit of that type..the legacy bit hogs off a great amt. in each pass, and of course one can use 1/4 or 1/2 shanks...so I would guess (not having used one, remember) that it might be a tad delicate...time will tell I thought I would post the picture as so many people had questions..so far I can see the following 1. a router screams..the dremel is WAYYYY quieter...2. the pen wiz can do the guilloche, legacy can't..3 .pen wiz is less than 1/2 the cost..If all you will make is pens & small items, I doubt the pen wiz will dissapoint If you want to do items like canes, the legacy is a must, or you can do it by hand, obviously . 4. the legacy will make a deeper rope than I suspect the little 1/8 rope bit will make (that's a guess)
