Patriotic 50 Cal.
See more from maxman400
maxman400
Omaha Arkansas
This is my entry in the casing contest, the :usflag:"Patriotic 50 Cal." :usflag:since it is .50" I used that number for my plans. I segmented the bottom and top of the case .50" from the beveled edge. I turned the the blank down to size then cut a tenon on each end to fit inside of the brass. The blank is Red white and blue and is from PSI, it is pressed in then glued. Every thing is wet sanded to 1500 then MM through step 5 and plastic polished.
Comments Welcome, Thanks for looking. :biggrin:
PaulDoug
Benton City, WA.
I like cartridge pens but I can't get into the look of the 50 cal. However I know good work when I see it and that is some good work.
