Patience With Another Finish
See more from rd_ab_penman
rd_ab_penman
Red Deer, Alberta, Canada.
On a Gold Titanium Ballpoint Cigar with Bubinga.
Sanded to 12,000 MM, applied three coats of Minwax High Gloss, sanded with 1500 grit between first three coats and then applied another final 3 coats. Wet sanded from 4,000 down to 12,000 MM and applied 2 protective coats of Brazilian Carnauba.
Takes more time and quite a bit patience to complete, but final finished results, I think are worth it.
As always suggestions and comments welcome.
MichaelS
USA.
I know I'm late on this, but more info on the process please. The finish looks like glass and sounds like it would last a long time under normal use.
