Padauk Copper Wall St II
See more from ToddMR
ToddMR
Columbus, OH
This is a Wall St II copper kit I got over at WC today. I started out using an acrylic which tore out on the end. Then lace wood and the same thing happened. Well I noticed my bushings only after using twice are rounded off already which is really weird for a bushing set. I know I might hit them etc when turning but even my cigar bushings I have had a while are still ok. So with that in mind I grabbed a piece of Padauk. I kept the ends a little thicker and sized with the bottom part of the kit. Good reason to have calipers I know. I sanded dry up to 600 and then applied HUT Crystal coat, HUT PPP wax bars. I then did 5 layers of Med. CA and did wet MM all the way up. I wasn't sure how the colors worked at first, but I think they look ok together. I am giving this one to my wife.
gmreeves
Birmingham, AL
The colors look good to me. I have a copper kit that I'm clueless what blank to pair with it.
How does the CA finish hold up on top of the wax?
ToddMR
Columbus, OH
Seems to do fine when I build it up enough. Its wax bars so I buff it up first. Then with the 5 ca coats seems to hold up for me.
