edstreet
keratin, buffalo horn. It comes in a range of color, mostly black. The higher grade material is harder to get and rather uncommon. They also present more problems to deal with.
This is still an ongoing work in progress.
continued from www.penturners.org/forum/f56/buffalo-horn-117516/
In this thread I will be showing off THREE pens.
Pen 'A' and 'B' was sent as a gift to professionals for their work and dedication in making the panda pen kit possible as well as other kits, i.e. george.
Pen 'C' is kept by myself. I not only like the look but it will be used as a control piece for a long term experiment. As many of you are well aware many here claim negative things when it comes to buffalo horn. Many here also refuse to use it for what I feel is bad exposure and bad experience and failure to adapt skill methodology to suit the material at hand. Enough about that however.
Pen 'A' was sent to Roy at Classic Nib
Pen 'B' was sent to Jon David Jones at Signature Pen Supply
Note here to the length. This is a short george. It *IS* a Gent Jr. Here it is next to my delicious beloved, a vintage Parker Duofold lucky curve, circa 1934.
Pen 'C' is my control test unit.
Many have ask why so short. The answer is very simple, because I can.
The next question is often what does it use? The answer to this is this one is setup to use a rollerball and a fountain pen.
Weight balance ratio is pretty spot on, 20.5g in the cap and lower.
standard length vs shorty length.
Refill cartridges for the fountain pen side. Photo courtesy Mike and Linda Kennedy from Indy Pen Dance.
Here we see the standard long international cartridge size on the top, below that is the short cartridges and converters available.
Here we see the following:
My Parker Duofold lucky curve on top (in reddish / orange ebonite),
Dayacom little Havana dressed in a Toni Ransfield set,
Berea El Toro (knock off clone of the Havana) also dressed up in a Toni Ransfield set,
Standard length gent Jr (george in black NIKKO japanese ebonite),
The short George in buffalo horn in antique silver with a #6 nib.
Also worth mention
As previously stated I used adaptive techniques to ensure there was *NO* heat generated during production, this includes drilling. In fact while drilling I would put the drill bit end to my bare hand to ensure no heat was produced. Never once was I burned.
Also worth mention
Ed, good luck. Cracking on hair horn, as Buffalo horn is keratin, the same substance as hair and nails will cause them to crack, as with things like snakewood, gator bone and others not all will but they are prone to crack.
Crack!!!!!!!!!!!!!!!!!!!!!
