Justturnin
Here are 2 attempts at a Bash pen. 1 is Cholla I cast w/ White and Copper Resin. I didnt paint the tubes and you can see it through the white resin on the ends. I went ahead and polished it up since I had already applied the CA. Next is my first attempt at a double dyed blank. It is buckeye burl w/ Red and Blue on a LeRoi Elegant. This in is cool because when you look at a blue spot you can twist the pen and it turnes red. Now to learn how to recreate that effect.
Edit,
Finish is, what else, CA. About .15mm thick.
C&C always welcome.
Edit,
C&C always welcome.
