Not sure which I like better
See more from BeeAMaker
BeeAMaker
Elkhart IN, USA
I made 2 blanks the same but with different methods to get 2 different looks. Not sure which I like better so I will leave it up to you guys. One of them I made into a Tiny Giant pen, the other is for an Aztec pen but I forgot to order the Aztec from Turners Warehouse so I will have to wait until I am ready to order there again so I don't pay $7 shipping for a $7 pen :)
So you get to look at both blanks after I cast them, and after I turned them, However only one will be on a pen. :glasses-nerdy:
Blank 1
Blank 2
The pen I made with blank 1
And a comparison to the other blank after turning.
I kind of like them both - Which do you like the best?
robutacion
Australia - SA Adelaide Hills
I like the first one better, don't ask me why...!
On the other hand, I can see that your casts have far too many bubbles and that can only be a problem, what resin are you using and do you use a pressure pot?
Cheers
George
BeeAMaker
Elkhart IN, USA
Cheers
George
Those aren't bubbles actually. What you are seeing are actually little "pimples" on the outside of the cast. That is because I didn't use my pressure pot when I made the silicon mold so it had a bunch of tiny bubbles on it's surface, so naturally the resin goes into these little air pockets when I cast to make pimples :) Because this is clear the pimple on the opposite side appear to be bubbles. I use a pressure pot regulated at 65psi with Alumilite clear.
I'll be making a new mold this weekend. I'll be sure to use the pressure pot on this one so i have a smooth surface to eliminate the pimple issue.
Thanks everyone for the kind words :)
