Not Fit for PITH
See more from broitblat
broitblat
Bellevue, WA, USA.
Here is one (of several) rejects I had on my way to a PITH pen:
The dye (food coloring) did not penetrate as deeply as I thought it would. I was hoping it would bring out the grain patterns, but instead, even a light finish sanding takes too much away.
I may experiment more with this, however.
-Barry
sbwertz
Phoenix, AZ
-Barry
Different woods take the dye differently. I use food coloring, but thin it with dna, so that it doesn't raise the grain. I give it a last rub with a paper towel dipped in the dye after MM #6 to even out the color. The higher grits won't take off the dye.
dozuki
washington, dc, USA.
When I colored some maple I turned and sanded them untill just about finished and colored them with prisma color markers and finished wi ca.
EBorraga
Passed Away July 17, 2022
Louisville, KY
Barry, I have good success turning to size. Sand to 600 then coloring with food dye, then I let it set overnight. Next day put your normal CA routine on without sanding before. Then final sand and voila.
DurocShark
Anaheim, CA
I raise the grain first by soaking and wet sanding the wood. Then I dye.
That said, pine's a beyotch to dye and get good even colors.
