My MAPG Pen
See more from Indiana_Parrothead
Jasper Indiana
Some things have come up that I will not be abel to attend MAPG later this week. But since I put some time in on this pen I thought that I would go ahead and post it. I know the pictures are bad, some serious glare from the lights, no light tent.
It is a segmented watch parts pen on a full size Emperor. The dial on the watch is a Breitling Chronometer and the wood segments are King Wood. I had started off with the segments being Tonga Nuts, it took one nut for each of the segments. As I started to get the blank round on of the segments shattered. I cut up and sanded 4 more nuts and could not get a big enough clean piece to get another band. I think the King wood turned out okay anyway. The finish on the King Wood is CA.
Thanks for looking
Band Saw Box
Passed Away Dec 8, 2021
Hampton, VA 23666
Mike; that is an amazing looking pen, spot on fit and finish. I really like the segmented blank it takes it up a few notch's. Sorry to hear you are unable to attend the MAPG.
Jasper Indiana
Mike, that is a beautiful pen! Please describe the segmenting process you used. Did you tenon the carbon fiber cast?
I painted the tubes a flat black and glued on the carbon fiber with CA. Then turned the ends back down to the tube. I made up my pieces of the tonga nut and and glued them on with epoxy. Then glued all the watch parts on as normal and cast in epoxy.
When I started to turn it one of the tonga nut ends just exploded, that is some really hard stuff. I tried four more nuts to try and get another end segment without cracks and finally ran out of nuts. So I turned off the other three and cut and drilled pieces of king wood. I ended up taking off more of the end than I wanted to to get a clean joint.
Glued on the king wood with epoxy and then sanded the ends down on a belt sander. Then it turned pretty good.
Janster
Nevada
..Very nice pen and a great SAVE! Be well......Jan
elkhorn
Utah
Outstanding! Great job, my friend. If it stops telling time, just box it up and send it to me. My wife says I can't tell time anyway when I'm in the shop:big grin:
Fit and finish are spot on.
OZturner
Sydney. NSW. Australia
What a Beautiful set of Blanks, and a mind blowing journey, Mike.
I love your recovery, it makes the Watch Components look like an Insert in the King Wood.
Outstanding components, Beautifully Prepared and Strategically placed.
Superb Fit and Finish.
The signature of a Dedicated Craftsman and a Perfectionist.
Congratulations,
Brian
