Not my first try, but my first completion :wink:.
Walnut and burmese rosewood, thats a piece of aluminum roof flashing in the middle.
These were a couple of scraps, the inverse of which failed to stay together. I tried cutting a quarter circle pattern through with the bandsaw, but it really doesn't show. It also made it harder to glue up. The scraps weren't even sizes, and that didn't help either. I drilled it on the lathe and it came apart there - i just took the part off that failed, drilled the rest of the way , then went back and finished the other side. With a tube in the middle, I re-glued in a clamp.
comments and suggestions welcomed.
