My HF lathe arrived today and after a little set up I turned my first roller ball. It an Olympian II Elite from PSI. It was a starter kit that came with two kits, bits and bushings. I had two problems one I found while drilling the upper blank, it seamed to drill funny and it looked as though the bit was bent, when I got done I check the bit and it did have a slight bend. I call PSI told them of the problem are sending me a new one. The second problem was in gluing the tube the upper blank the glue set before I got it passed the end of the blank. It didn't cause to much of a problem in the finished pen.
I used Lacewood and finished it with Hut crystal coat. It was a fun pen to make and I think I wasn't to try other kits. I ordered a ten pack of slimline kits that I going to give as Christmas gifts. Any and all comments are welcome. Thanks for taking the time to look at my work.
