My first pens too
See more from GaryMGg
GaryMGg
McIntosh, Florida, USA.
Tony,
Thanks.
Yep, these are definitely my first pens. However, I've had the lathe long enough to
turn some cylinders, two rolling pins, some dowels, lots of finger tops, and some
other stuff. So, it's my first pair but it's not the first thing I've turned.
They're both just basic slimline kits without modification.
Cheers,
Gary
GaryMGg
Eric,
I've known it's a slippery slope. [:D] I've got about another dozen slimline kits.
Gonna have to find out what else can be made with those.
I need to buy some wine stopper and keychain kits, 'cause I know a couple of
folks who'd like those as gifts too.
Thanks,
Gary
BigRob777
Newark, Delaware, USA.
Gary,
Very nice first pens. I didn't see any descriptions, but I'm guessing that the top one is bloodwood. I like it best. One idea is to turn your own center bands, so the pens can be thicker, without having a figure 8 look. I'm sure you can find a tutorial on making your own CBs here somewhere. I'll try to crop a pic for you to see what I'm talking about. Keep in mind that I'm still trying to perfect it.
<br />
I'm sorry, but this was a magnified piece of a much larger picture and the res. is pretty bad.
I think that this pen's about 25% thicker, or more. I've done thicker too. I think you'll like doing your own, as it expands what you can do with them. I'm saving up my CBs for something wierd. I've no idea yet. Have fun and keep up the good work.
Rob
Joe Melton
Colorado Springs, CO, USA.
Here is a site with some technical information on your wood:
http://www.mnh.si.edu/biodiversity/bdg/medicinal/MedPlantsGui3.pdf
Nice work, by the way. It is not an easy wood to work with.
Joe
OSCAR15
Winder, Ga, USA.
Nice Work Gary! Although most kit sellers recommend starting on slimlines, they are actually harder than many other kits.....
Cigars are easy as are Polaris.....Welcome to the addiction.[:p]
GaryMGg
The one the right is lacewood.
The one on the left I believe is rosewood. Not 100% sure as it
was laying around the shop for some time. It's possible that it's
Brazilian cherry or some such variety. Very dense, somewhat oily,
no discernable aroma, and turns easily. It's very dry and the shavings
were more like little little chips. I went rather carefully using a
skew and shaved it carefully as I closed in on the final dimension.
It also takes a nice finish with a sharp handplane.
Gary
