rd_ab_penman
Chrome ballpoint. Acrylic White with Black Stripes. Wet sanded and polished down to 12,000 MM.
Top barrel uses 8mm tube. Clip is spring loaded. Has 1/8" tenon for pressed on center band. A sleeve is pressed inside center band end of the 8mm tube to accept 7mm transmission.
Lower barrel uses a 7mm tube. Used both an A Mandrel and a B Mandrel to turn blanks.
As always suggestions and comments welcome.
