My first Olivewood (BOW)
See more from KKingery
KKingery
De Pere, Wisconsin, USA.
This is my first attempt at using BOW. It's made using a slimline kit from CSUSA. For someone that isn't overly fond of olives, this was a true turning experiment. Good Lord this stuff does smell like olives! This one isn't for sale - it's a gift.
Any comments are welcome. - Thanks, Ken
PenWorks
Scottsdale, AZ
Very nice Ken, glad you made it back into the shop and started to make some pens, to pay for your new truck [:D]
Anthony
dougle40
Essex, Ontario, Canada.
Nice looking pen Ken . I just drilled amd glued up my first piece of BOW tonight . It must have had a crack in it because it split on me while I was drilling . Luckily the piece only split and didn't break , so I parted the split a bit and put some thick CA into it and clamped it up . Hopefully it won't blow up tomorrow when I turn it .
Gary
Texas, USA.
Been there and done that Doug. As you turn through that split area, be sure and add some thin CA. It will help you get through it without a breakout.
KKingery
Well, I've got 4 more blanks on-hand, and another five on order. This particular blank that I used, looked to be the plainest of the 5. From the outside, it really was'nt anything spectacular.
Lou
Washington, DC, USA.
<s>Ken</s> Ooopppsss! Doug--although Bethlehem olive wood appears benign, it is fairly susceptible to blow out if much heat builds up. Being extremely oily, the heat expands the oil and...BAM! Take it just a little slower and clear the drill more frequently than with more traditional hardwoods.
G
Guest
Guest
The first pens I turned were out of BOW.I dare say yours cam out much better.
I tought all wood turned like BOW(wrong)
If you want to try something else that turns as sweet as BOW try bocote.
