My First Kitless Slim Click Pen - Page 3 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Show Off Your Pens!
  Forgot Password
Show Off Your Pens! Let's see your best work!
Welcome to penturners.org!
Reply
Old 03-22-2018, 12:59 PM   #21 (permalink)
Photos: 0
Default
Mal, looks like the suitable size has been found. Iíll bookmark online metals.
What I was referring to I get at a local hobby shop.
To Dans point, the act of drilling a tube will increase its OD if its not restricted in a collet. I think Iíll try it and report back.
I fully expect you to develop a version thatís ďdressedĒ.
PatrickR is offline   Reply With Quote Top
Old 03-22-2018, 01:34 PM   #22 (permalink)
Photos: 0
Default
FWIW
I drilled a small section (all measurements with a cheap digital, so +/-)
Tube .311 OD, .235 ID
I tried a .294 bit . No Way
Next a .292 bit. The OD became .320, ID .304. Making a flexible yet sound tube with a ribbed exterior.
Old 03-22-2018, 01:48 PM   #23 (permalink)
magpens's Avatar
Photos: 75
Default
Thanks, Lewis, but there is a strength reduction with using that tube.
I assume the wall thickness is 0.049. . So 0.375 - 0.049 - 0.049 = 0.277" bore.
Currently I axially drill 15/64" = 0.234", so I would be losing (0.277 - 0.234)/2 = 0.021" .
That may or may not be satisfactory ... actually, I think it would be OK as aluminum is fairly strong.
Current wall thickness is (at center) (0.332 - 0.234)/2 = 0.049 ... I think I calc'd that right.
Your suggestion would certainly be OK on the ends where I bore out to "M" size = 0.295"
Do you think 6061 would be a better grade to use ? . I do not know what grade I bought for this job at Home Depot.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Advertisement
Old 03-22-2018, 01:59 PM   #24 (permalink)
magpens's Avatar
Photos: 75
Default
Patrick,
I don't know about what you are doing there ... I mean I get it ... but I have serious reservations about the "flexible ... with ribbed exterior"
I think we can get to a dressed design but not via the route I am on. Will have to reduce the "M" size hole in both ends ... Maybe revert to a 7 mm full length brass tube, which is probably the minimum to accept a Parker ... hole is right around 0.250 and the Parker is 0.226, so that means 0.012 clearance ... OK. . Obviously we already know how to dress that.
That clicker becomes the clanger. . I won't be able to use the clicker mech I currently use. . An alternative is the Schmidt clicker from Greenwald or Milan but I think its OD is too big (bigger that 0.332).
__________________
Mal
Old 03-22-2018, 02:00 PM   #25 (permalink)
stuckinohio's Avatar
Photos: 3
Default
I think 6061 would be one of the better grades. I think there are stronger grades of aluminum, but not sold in tube form.
I choose that size because you needed a size thicker than .33 and with an ID that could be bored out to .28 or .29
I do like Dan's idea of threading the bar stock to accept the nose cone and skipping the adapter.
__________________
Lewis
stuckinohio is offline   Reply With Quote Top
Old 03-22-2018, 02:02 PM   #26 (permalink)
Photos: 3
Default
You'll have to use the smallest clicker I linked to I think.
__________________
Lewis
Old 03-22-2018, 03:18 PM   #27 (permalink)
Photos: 0
Default
Mal, just showing what happened when I drilled that tube to that size. Useless for your intent.
I measure the Schmidt clicker at .323 small enough, a much better mechanism and it would remove the need for a screw on nib.
Old 03-22-2018, 05:08 PM   #28 (permalink)
Photos: 1
Default
2024-T3 is roughly about 1/3 stronger than 6061-T6 with 7075 alloys being roughly a third stronger again.
Good on you Mal for trying to make a better skinny pen. ;)
__________________
Pete
Proud to be the support staff and enabler of Marla Christensen.
Curly is offline   Reply With Quote Top
Old 03-22-2018, 09:01 PM   #29 (permalink)
Photos: 3
Default
Good to know!
__________________
Lewis
Old 03-22-2018, 09:03 PM   #30 (permalink)
Photos: 0
Default Thanks for the Reply
Quote:
Originally Posted by magpens View Post
No attempt to color the aluminum, Gary. . The color is a photographic artifact and not real. . I don't understand how it came about but then I don't understand lighting for photography either.
As for the polishing there are a couple of options. . First, Silvo or probably Brasso metal polishes will do it ... there are others also specifically for metals.
I think I will probably try Mequiar's automotive cut polish to remove the fine scratches, followed by Novus 3 and then Novus 2 and then finally Mequiar's Plastix maybe, although that is not designed for metals. . That is my usual procedure with acrylics
Thanks for the Reply Mal.
Yankee Remedy is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
