My First Kitless Slim Click Pen - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Show Off Your Pens!
  Forgot Password
Show Off Your Pens! Let's see your best work!
Welcome to penturners.org!
Reply
Old 03-21-2018, 11:24 PM   #11 (permalink)
magpens's Avatar
Photos: 75
Default
No attempt to color the aluminum, Gary. . The color is a photographic artifact and not real. . I don't understand how it came about but then I don't understand lighting for photography either.
As for the polishing there are a couple of options. . First, Silvo or probably Brasso metal polishes will do it ... there are others also specifically for metals.
I think I will probably try Mequiar's automotive cut polish to remove the fine scratches, followed by Novus 3 and then Novus 2 and then finally Mequiar's Plastix maybe, although that is not designed for metals. . That is my usual procedure with acrylics
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 03-21-2018, 11:46 PM   #12 (permalink)
Photos: 12
Default
I like the threaded nose cone. Apparently necessary for your design to work, but even when it isn't necessary I think it's a nice feature. One of the reasons why I like the Zen kit, you can flip the barrel without disassembling, but I digress. Nice looking "Parker slim" you have there Mal. I wonder if the manufacturers could make a 7mm version of the Stratus, where the click mechanism and end cap are a single piece. This would allow for a typical wood dressing. Anyway, well done and keep it up Mal.
__________________
--Sam
Dehn0045 is offline   Reply With Quote Top
Old 03-21-2018, 11:52 PM   #13 (permalink)
magpens's Avatar
Photos: 75
Default
Thank you, Sam !
Interesting thought about the Stratus ... but I don't think manufacturers pay any attention to what pen turners really want !!
__________________
Mal
Advertisement
Old 03-22-2018, 04:57 AM   #14 (permalink)
DJBPenmaker's Avatar
Photos: 0
Default
Well I've tried to follow this but my skills obviously lack in this direction, it's all way above my head I take my hat off to you Mal.
Sent from my SM-G955F using Tapatalk
DJBPenmaker is offline   Reply With Quote Top
Old 03-22-2018, 07:46 AM   #15 (permalink)
magpens's Avatar
Photos: 75
Default
I wouldn't say that, Derek. . It is like so many other things ... once you get stuck into it you realize what you can and can't do, you do what you have to do, and it all works out when the constraints are recognized and dealt with. . Don't forget that I had been thinking about this for several days ... probably longer ... and the steps eventually became clearer as I went along. . If you have any questions be sure to ask. . Thanks for the kind words.
And don't forget ... the goal of this presentation was not a perfect realization of the objective, but just a step in the right direction which can be improved upon.
I left some things undone and "rushed to press" because I didn't want people who had contributed to the earlier thread to forget about what they had contributed, or think that I had. . So I wanted to get more feedback about the project by showing a nearly finished possibility for a pen.
__________________
Mal
Old 03-22-2018, 09:22 AM   #16 (permalink)
stuckinohio's Avatar
Photos: 3
Default
Quote:
Originally Posted by magpens View Post
Quote:
Originally Posted by stuckinohio View Post
Very nice Mal! Interesting way of approaching the nose cone idea. For the clip, since you are using the slim line diameter, couldn't you just use a clip from a slimline?
Oh, and sorry for stealing your second post!
Yes indeed, you could do that, Lewis. But you have to drill out the hole.
You don't have much material width; ie. the hole you need is not much smaller than the diameter of the clip support ring.
I think this would be very tricky to do successfully.
Oh yeah, I forgot you were using the collar from the pro kit!
__________________
Lewis
stuckinohio is offline   Reply With Quote Top
Old 03-22-2018, 10:35 AM   #17 (permalink)
Photos: 0
Default
Nice work Mal. Im looking forward to seeing how it progresses.
Reducing that clip diameter will be interesting. Id think a mill would be the tool.
You may be able to save some time by starting with aluminum tubing. I have used some that is roughly .311 OD x .240 ID.
PatrickR is offline   Reply With Quote Top
Old 03-22-2018, 11:04 AM   #18 (permalink)
magpens's Avatar
Photos: 75
Default
That specific size tubing would not work, Patrick, because it would need to be bored out to an ID of 0.295" at each end to accept the nose_cone_coupler (at one end) and the click mechanism (other end). . The resulting wall thickness would be only half of 0.311 - 0.295 = 0.008" and that would destabilize and crack in the drilling process.
Of course, a tube of OD 0.33" is really what is needed. If that size is available, then, after the boring, the wall thickness would be 0.017" and that might we able to withstand the stresses of drilling.
If you can, please suggest a source for aluminum tubing of such sizes.
If Al (or other) tubing of a little bigger than OD 0.311" is indeed available to me, then it could be used in the manner that brass tubing is used for pens (ie. glued inside a wood or acrylic blank) and that would strengthen the tube for careful drilling and might allow my type of pen to "wear" a wood or acrylic dressing.
That would be an interesting challenge !
__________________
Mal
Old 03-22-2018, 11:14 AM   #19 (permalink)
More4dan's Avatar
Photos: 5
Default
You may be able to use a small boring bar it gently increase the ID of the tube at the ends for couplers. Could you thread the rod/tube instead of using a coupler?
More4dan is offline   Reply With Quote Top
Old 03-22-2018, 12:31 PM   #20 (permalink)
Photos: 3
Default
Here is suitable tube, I think.
0.375" OD X 0.049" 2024-T3 Bare Drawn Aluminum Tube - Online Metal Store
some in 6061
http://www.onlinemetals.com/merchant...=71&top_cat=60
__________________
Lewis
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
